This locomotive is in excellent condition, hardly used, and only indoors.
It has a factory fitted LGB decoder. It has directional lights front and rear, cab light, a very effective smoke generator and square multifunction sockets at front and rear.
I have added a Massoth S sound decoder with specific sound files (Massoth 821x047) with 2W 8ohm speaker, and a Massoth Automatic Uncoupler 8414002 to replace the rear LGB hook and loop coupling. The original coupling is included as are the original instruction leaflet and Massoth sound sheet. It comes in its original box and packing which is in very good condition.
To see the full effect of the rack and pinion coupling and valve gear movement you need rack rail to be installed between the tracks, so also provided is one pack of 12 rack rails (LGB 10210) and one pack of 24 rack rail holders (LGB 10220). Finally an extra fireman figure has been added to complement the factory supplied driver figure in the cab.
The decoder is set to address 8. The function keys are as per the Massoth sound sheet except for F8 which is used to operate the automatic uncoupler.
This excellent model is for sale for £700 including P&P to UK address.
There are several more pictures below plus four video clips of static loco, in motion over rack rails, automatic uncoupler and smoke generator in action.
