I have a (very 'new' looking) 2003 vintage Streetcar here..
When you run it at medium, or higher, speed it will keep cutting-out and then starting off again..
On analogue rolling road, it will draw in excess of 3Amps when running at a reasonable pace. This seems to cause the decoder/electronics to keep 'crowbarring' and cutting-out.
I think this may be (obscurely) a lubrication problem.. If I use a DVM to check continuity down the wheels and skates one side of the loco, I tend NOT to get continuity. - In my book, as all the axles have the carbon-brush pickups, then every wheel and skate down one side should be connected together.
There seems to be a fair amount of 'oil' (is this from the grease breaking-down over the years?) coating the brush-holders, contact strips for the skates, and the 'wire-rod' which relies on pressure from the cover to hold everything in contact.
I will try to 'de-grease' the electrical pickup-chain within the motor-blocks for a start..
Second problem:
Has anyone ever managed to get into the bottom of one of these units??
I have removed all the visible screws (including those under the frames at either end) and applied a more-than normal amount of force to try to part the black chassis from the body. No luck.
Cheers,
Second problem:
Cheers,
