maxi-model
Give these people a go http://www.starloc.eu < Link To www.starloc.eu . Found them at the Midland Model Engineering Exhibition a couple of months ago. They seem to have adhesives for every occaision. Especially various plastics applications. Given that must plastics adhesives are solvent based then getting away without marks is going to require care. How will the windoow be fitted ? Flush or on the surface ?
If you are still not sure why not try thin strips of heavy duty double sided clear tape and use that to fix the perspex on, assuming you are fixing from the inside and not needing a flush fit. If flush fitting, try Microscale Kristal Klear. It is a PVA type glue that will not attack plastics and can be wiped off. Thin it down with water 50/50 and let good old capilary action take over and flow it into the gap betwixed window and body.
I use both metods depending on the situation.
Max
Max
