Inspired by Don Henry and his Stonycombe railway I decided to stop prevaricating and actually do something. 8|
My (yet to be built) garden railway will have plastic electric cable conduit (with the snap on/off lid) running adjacent to the track carrying 2 x 12 core cables. Hopefully this will look similar to lineside concrete troughing that the big boys use in the 1:1 world.
There will be break-out points at several locations where the wires will be accessed for points, lighting etc. These will be 2 x 12 way 'chocolate blocks' mounted vertically or horizontally covered by a suitable weatherproof structure. I had read somewhere that cut up tin cans could be used for realistic looking corrugated iron so a lampmans hut built entirely of the stuff was an ideal (and hopefully easy) prototype.
First I built a wooden former out of scrap plywood (Picture 1) stuck together using waterproof wood glue.
I then cut up 4 cans using strong kitchen scissors (Picture 2) and straightened the resulting sheets as best I could.
Suitably sized pieces of tin were cut with the scissors as square as possible and stuck onto the plywood using silcone sealant, securing the pieces in place using cheap clamps (Picture 3 and 4).
Both sides were clad first and then left clamped overnight and then the front and back and again left clamped overnight resulting in a hut with no door or roof (Picture 5).
The roof panels were cut next using the natural curvature of the tins to advantage (Picture 6).
Another overnight wait for the sealant to dry left me with a roofed hut but no door (Picture 7 and 8).
The separate parts of the door including hinges were assembled and stuck together using superglue and activator (Pictures 9 and 10). The tin is thin enough to push a sharp point (in my case a phillips jewellers screwdriver) partly through from the rear to reproduce bolt heads.
Ade
Ade
