trammayo
A large proportion of my stock uses knuckle couplings or buckeyes. Sometimes they can be a pain - drooping or swivelling around when you try to couple up. It is the latter problem that I found a quick solution to.
The good old bass broom (or at least its' modern equivalent). Yes, the're not just used for sweeping or witches transport!
The clumps of bristles are stapled into the brush head and, occasionally, the staple drops out.
I had already thought that the stiff, springy nature, might be a substitute for the plastic tail that keeps the coupling central on the truck's stem. Sometimes that tail breaks off and then you have to hold the knuckle to align with the next item of stock in the train when assembling your consist.
So, a 1.5mm drill in a pin vice, drill out where the broken tail used to be, and insert your brush bristle with drop of plastic cement to keep it fast. Then just snip to length!
And that's it. Bristling with success.
