Loco
Here`s a comparison between a slow moving Kaleas switch motor and the standard fast moving LGB switch motor. Kaleas was previously sold under the name Böhler, so if you want to search the web for more information you will most likely find information with latter name.
First a few pictures of one of the units I have aquired.
Kaleas switch motor type WA1 which has an integrated feedback relay which corresponds to the LGB switch motor with the 12070 supplementary switch addition. The supplementary switch/feedback relay is used to give a feedback of the switch position to a control panel, a PC control program or similar. The Kaleas switch motor is mounted on a LGB adapter plate and then connected to the switch. The switch is a LGB R5.
