One thing that should also be considered, the phrase "will body mount work on R2 curves" is a poor question to answer, and those of us with experience need to help out a bit.
Question: 1: Will a train with Kadees body mounted run fine on R2 curves...
Answer: yes and with 50' cars and sometimes over, long locos might need a short car coupled..
But another question is: "can I use the remote uncoupling magnets" with body mounts and R2 curves:.
Answer: well, maybe but it might be iffy, and definitely no cars over 40' and that is pushing it.
And the final question in will it work: "can I couple cars on R2 curves with body mounts"
Answer: no they will not align on an R2 curve, so you will have to couple them by hand.
So these are 3 different ways to answer "will body mounts work on R2 curves".... it's all in the concise definition of the word "work"...
Therefore to the OP: if you don't need to automatically couple and uncouple on the curves themselves, go body mounts, you will get more reliable operation, R2 curves are fine.
If you want to couple automatically on the curves, then go truck mounts
