Ralphmp
I have a Mallet where the front motor block has the "hesitant start" lurgi - doesn't want to turn at first but after a few seconds grudgingly comes to life, then runs fine for the entire running session and then exhibits the same hesitation next time it's put out on the track.
I've cleaned up the motor block (a previous owner appears to have used a car grease gun to lubricate the gears so there was grease everywhere - yuk!) and fitted new brushes and this has improved things a bit but the problem is still there. I've also checked and rechecked the quartering is ok and, despite the loco only drawing 0.5 amps when running round the layout with a couple of coaches attached, I'm coming to the conclusion that it's the motor that's poorly.
I'm really not up to refurbishing the motor so for peace of mind I'm thinking of fitting a new one. However I'm not sure if this will promptly put unwanted strain on the existing motor that's currently working fine. "Logic" would seem to say it's best to replace both motors at the same time, but before I go ahead I wondered what other folks' views / experiences are on this.
Any comments would be much appreciated.
Thanks
Thanks
