Rod Fearnley said:Mike I don't know if this will help or not. I made my own lift out's. I brazed brass angle stock to the ends of tracks that the bridge will sit in. Make sure that the angle is hard against the track flat bottom. Obviously the track on the bridge must match the track with the angle brazed to it. It works for me.
Sounds a clever idea. The only drawback I could see would be one of ensuring good long term electrical conductivity without the need for constant cleaning or "jumper" leads. I have done something similar to connect my indoor track to the outside through a cat flap, but the entire shebang is in the warm and dry.Rod Fearnley said:Mike I don't know if this will help or not. I made my own lift out's. I brazed brass angle stock to the ends of tracks that the bridge will sit in. Make sure that the angle is hard against the track flat bottom. Obviously the track on the bridge must match the track with the angle brazed to it. It works for me.
tramcar trev said:I'd like a few ideas as I intend to extend my tramway across a 3 metre driveway so I can run along my side fence. Also if anyone has done this with overhead before how did you solve the problem of alignment of the overhead wire?
I like the bridge - is it pivoted on the right-hand side? In my current garden I have a hinged LGB bridge with the Hillman clamps, but in my imaginary future line, I would need to have a much longer span like yours, and so I am very interested in what you have done.trammayo said:I just rework a couple of rail joiners (LGB type) to form a channel to allow the bridge rails to drop in. The weight of the bridge usually ensures electrical continuity. You could put a small jumper connection in - it only takes a second to plug together.
It may work... I have had a look at how its done in full size practise. I may be able to use an inverted brass "V" section and the trolley wheel would run inside that. If say the V section on the lift out part was longer it would sit on the V section on the "land" sides... I don't know, its all up in the air ATM..... Alignment is going to be the problem.dunnyrail said:I would look at a length of thin wire with a Hook and Spring to maintain tension. With a join via a raised pull off may just work. Would probably need to be a couple of feet long and maintained on the Lift Out section so that it is not in the way when the extension is not being used.
JonD (pie in The sky department!)
viaEstrecha said:I like the bridge - is it pivoted on the right-hand side? In my current garden I have a hinged LGB bridge with the Hillman clamps, but in my imaginary future line, I would need to have a much longer span like yours, and so I am very interested in what you have done.
I remember getting the hinges direct from the US manufacturer, but I can't remember if I got the clamps at the same time!
