Highlighting piping on a backhead using a leafing pen
  • Thread starter Thread starter GAP
  • Start date Start date
GAP
G Scale Model Trains, 1:1 Sugar Cane Trains
I use a "Krylon" brand "Gold Leafing Pen" borrowed from my wife`s card making toolbox to highlight the polished brass piping on an LGB steam loco`s backhead.
I have attached some pictures of the completed one and another prior to getting the treatment plus a picture of the pen.
[attachthumb=1]
[attachthumb=2]
[attachthumb=3]
Yes like that,very effective :)
That looks great - the water and pressure gauges very lifelike!
Those pens are very good, I do lots of gold lining with them, they also make a copper coloured pen as well for copper pipe etc....
http://www.ebay.com.au/itm/Krylon-Leafing-Pens-Copper-/151402947942?pt=AU_Scrapbooking&hash=item234051a566
To make the work weather proof and give it some protection I then go over the line work with one of these;
http://www.ebay.com.au/itm/Simoniz-Clear-Coat-Applicator-Car-Scratch-Remover-Scratch-Repair-Painting-Pen-/360675915188?pt=AU_Car_Parts_Accessories&hash=item53f9f5b5b4
This needs UV light to cure it but it is very good to go over polished brass etc to keep it shiny...
You can also use a silver one to touch up around coach window frames.
Hi Trev
Is the point fine enough for lining? I might give it a try, if so.
Rik
ge_rik said:
Hi Trev
Rik
The tip can be cut with a new exacto blade to whatever size you want, without cutting they are about 1.5mm wide.... Tips are a fibre type chisel shape....
For fine work, I pushed the pen down to dispense a pool of paint onto a piece of styrene and then use a fine artist brush, just have to small bits at a time as it dries quick.
Clean up was with good old metho (methylated spirits for overseas people ;) ;) )
The pen I used is one of SWMBO's that the tip has frayed to much for her card making.
great idea..Nicked!! :o
