stevedenver
last time i ran this trolley there were no issues. it was last run, about 3-5 months ago. put into its box. nothing unusual, not dropped. bone dry.
1 problem: runs great one direction, appropriate head and tail light work, in reverse, however, it creates a "short" ie barely any slow movement in other direction, (clearly something is crossed with a trickle of electricity still getting to the motor despite the load of the short) , then trips breaker.
this problem appeared this morning on the track. I tried a few reverses. all still had the above short. But,
2 for a very brief moment, this short went away when i reversed. Trolley traveled maybe an inch. then reappeared. short still there.
3 took off roof, no difference. short still present
4 slid track/catenary switch several times between catenary to track power, no difference.short still present. disassembled chassis frame section that holds block to body.
5 examined printed tracer board (under passenger seating area) which directs track /catenary power and which g-y-w lead connects to motor block as well as being connected to this board and which supplies power to the brass roof contacts. no visibly apparent connections between circuit printing , solder point, and wire feeds. ran a screw driver between printed sections which are close just incase, no change.
6 removed motor from block, motor works great both directions.. reinserted motor into block and then attached power clips to appropriate motor block pins (old three pin style, no problems, no short in both directions.
7 with roof still detached, BUT now with car wiring harness attached to block, I still have uni directional short. so, its in the car lighting circuit i guess. More specifically in the head light, tail light or under passenger feeder board.
8 i removed the body platform ends, in which head lights and led tail lights are housed, red tail light LED boards are housed, they are connected to the small marklin inter car lighting circuit plugs. I examined each board for any connection between soldering and wires etc. nothing i can see. No discoloration of a fried component (but i didnt allow the short to persist long at all). again ran a screw driver between the very close printed tracer sections just to make sure these was no connection.
9 removed headlight 24v screw bulbs to eliminate bulb issue. no change. still have short. Examined bulb bases, all appears fine, no frayed wires, base contact and threads all clean.
10 gently moved/wiggled the LED circuit wires which are soldered to the mini board with the diodes. I tried this just in case there was a stray wire strand, bare portion of insulation etc. still have short.
the trolley is clean, no corrosion, no dirt, basically almost like new. upon disassmebly, very little in the way of dust, grit, etc.
i dont know what to do. i suspect a diode failure, but i am ignorant of this stuff and how to check. it is very likely i am wrong about the diodes, its just a guess.
help please.
help please.
