brianthesnail96
<p>Hi again all, does anyone know if a stock Ruby burner is the same as an Edrig's? Found some useful articles on MLS (heading in a slightly different direction, but on similar lines- they suggest that the flow through a standard burner is too fast, but deal with it by reducing the jet size and also partially blocking the air holes on the burner- however this should have broadly the same effect as fitting a holed burner I believe. Also I'm not sure reducing the air side of the mixture is a great way to achieve higher efficiency personally!) that are Ruby related and I'd like to know if I can use the information directly or rescale to suit. </p><p>Also (more importantly in fact) what size the standard Accucraft gas jet as found in an Edrig please?</p><p>Cheers folks
</p>
</p>
