Philip Sharp
Thanks for adding me.
Welcome Philip. Good idea having several layouts, garden railways are great, but the weather can be a problem!I have been in the hobby of model railroads for two years and became interested in garden railways about 10 months ago. Instead of building one largish layout, I plan building several small layouts in different scales. This piques my interest more than having one layout of one scale. In addition, building small layouts instead of one largish layout will mean I will have to wait less time before I have a completed layout.
For my small garden layout, I plan having dual gauge, 32mm and 45mm.
I am taking things slowly so as not to overcommit myself.
Philip
Dual gauge lines are another great idea, although if you build your own track it can be difficult at the points or turnouts.
Welcome Philip.
Many moons ago on my layout at Luton ai built a dual gauge circuit because the guys from the local 16mm Group were too lazy to change the gauge on their Live Steam Dragons. That circuit had a Mixed Gauge couple of Points and a 45 Gauge Crossover all scratch built using Flat Bottom Bonds Rail and their Brass Trackpins that look like a 7. Complete pain in the butt as the Wooden Sleepers on Compaction and Compression used to push out the Brass Pins. I had to go round the complete layout with a Hammer and a pair of Pliers to knock them all in again to find that they had lifted again the next time I wished to run. I sort of resolved some of it by using Steel Pins that would Rust in place keeping the Track together, but clearly this was not a permanent solution. In the end I gave up and changed it all for Peco G Scale Track.
However on Points, depending on the Rail that you use the Point Blades will need a lot of filing down and a Jiggle is worthwhile on the Stock Rail. Frogs also need to be fasioned with care and Bonded together with a good dose of Solder or better still Silver Solder.
Stub Turnouts will reduce a fair bit of that work, but can be a little trickier to get working long term reliably. You would certainly need to set the Track on a good permanent base, perhaps a paving slab with Metal underneath the rail to provide a place for fixing screws.
Another method of track construction that I have seen is to cut up Mains Wire to make a U, drill the sleepers then push the U from below the Rail clamping it it place with a pair of nippers. Perhaps a good dash of solder as well. If you go down this route you will need to be very accurate with the holes that you drill, perhaps fiendishly difficult on dual gauge points.
Finally you mightblike to look at this mans threads,msome interesting Track Methods
https://www.gscalecentral.net/threads/eltham-south-electric-tramway.307019/
Good luck and please post some pics of your progress.
Ah, that sorts out a bit of confusion in my mind, you said you lived in Auckland but the forum wa giving you a British locationThanks for the detailed comments.
Are you currently in Luton? I'll be at Highams Park for another 10 days before returning to Auckland.
I bought some track spikes in the shape of 7 from Sunset Valley. I have practiced a little using the spikes to attached track to plywood sleepers. I quickly learnt that there were a lot variables such as the depth and diameter of the pilot hole, and the angle the spike is pushed in. I don't mind tightening the spikes once a year, before every session would be a bit much. I am undecided what wood to use for the wooden sleepers. Perhaps yellow cedar, there is a supplier in New Zealand.
What is a Jiggle in the sense you are using it? Googling did not help me.
I plan to build up to DG stub turnouts on a garden railway using something like the following steps
1. Make a couple of stub turnouts in HO.
2. Make a couple of stub turnouts in 32mm.
3. Then have a whack at the DG stub turnout.
Philip
Can't find a picture of a jiggle either, although I know what Jon means; a notch is more common
Although I would hasten to add that I do not build my own points, although I was tempted once and started something.................................![]()
Good luck with all of that.Thanks for the detailed comments.
A - No in St.Neots now.
A- Whatever wood you use for sleepers, do not use ply no matter what the manufacturer says it will not stand up long to your wet climate. However in a good dry Shed or Garage it will be fine.
A - Basically you are doing is cutting a bit out of the Stock Rail to allow the Blade to sit in close. What Rhinochugger xpcalls a notch has been referedcto for years as a Jiggle by smaller gauge modellers.
Philip
Thanks Jon. I have been on the GRS website several times over the last 10 months but had not realized GRS custom-made dual grade track and pointwork. That sounds like a good Plan B. If I may wax philosophically, the journey is often more important than destination for me.Welcome to GSC, Philip - will look forward to seeing some pics of your dual-gauge line..... over here, GRS (Garden Railway Specialists) offer custom-made dual gauge track and pointwork, but if you have a local chap who can do it for you (or at least teach you how to do it) then it sounds like you're sorted!
Philip
Oh yes, we do philosophyThanks Jon. I have been on the GRS website several times over the last 10 months but had not realized GRS custom-made dual grade track and pointwork. That sounds like a good Plan B. If I may wax philosophically, the journey is often more important than destination for me.
Philip
Oh yes, we do philosophy![]()
Hmmm, I was in Cambridge one day last northern hemisphere summer.
Yep, plywood does not work in Auckland's climate. Creosote-soaked plywood might give you ten years if you are prepared to let some of your sleepers be seriously compromised. Creosote can no longer be sold legally in New Zealand. Not that it matters, I had no intention of using Creosote because it is unhealthy. The substitutes do not seem to work as well as Creosote. That leaves me undecided what to use for permanent sleepers (I don't mind using ply when I am learning). An Australian hardwood? New Zealand pine that has been treated to the H4 standard? H4 is suitable for fence posts, garden edgings and landscaping. Both of these options would be expensive per sleeper but if the layout is small the total cost might not be too great.
