a98087
As this been a few threads, I thought I'd post my advice about fitting RC to a lgb stainz loco
disclaimer
This isn't the best way to do things just a way I've found that works!!
It's a the same method as published by gregh on the sandstone and termite
Here's greghs link
http://www.members.optusnet.com.au/satr/2point4GHz.htm
1. choose your battery technology - a chose lipo due to size and weight
2. acquire all the parts you need:
Transmitter (tx). Mode 2 if possible, this puts the left stick normal position at the bottom not centralised
Receiver (Rx)
Electronic speed controller (esc)
Battery and charger
Servo
Dpdt toggle switch
Fuse
Lipo voltage monitor
On off switch
3. Dismantle loco and remove the following
Skates
Pick up bullets
If it's a 4 pin block the 2 pins that are the track pick ups, this is to improve the running of the chassis, and insulate from the track
4. Either solder a wire to each motor terminal, or use some female pin crimps, but you need about 6-8 inches of trailing wire leaving the motor block
That's the motor block finished
disclaimer
Here's greghs link
Receiver (Rx)
Battery and charger
Servo
Dpdt toggle switch
Fuse
On off switch
Skates
Pick up bullets
