OK chaps, here's the problem, and sorry if this blueprint isn't very professional, but as I keep telling you, I'm an ops man, let the technicians do the nasty work. Here we have the fairly classic dogsbone in blue, any idiot can do that (and I'm any idiot), and it all more or less works under the control of TM1. Inside the oval is a separate operation in green, and this should be controlled by TM2. It isn't, but I think there is a finger stuck in there somewhow, but we'll worry about that later. The idea was that this green line would be a simple out and back operation, although as you can see it makes an end on jucntion with the blue section. Possibility of blue sparks there if things aren't properly selected, I suppose. Now a new kid is about to arrive on the block, should be in the post soon, this being a crossover which will be inserted into the blue hatched line. This is not yet in postition. So what was a simple little oval with trains going round and round now becomes the dreaded figure of eight.
What happens next? Because I dunno. Should I take up aeromodelling instead?
