Andrew Foster
Not sure if this is the place to discuss tools, but we'll see. I've just acquired a Dremel 580-2 table saw, and to put it politely, it had not been treated kindly by a previous owner. Specifically, he had turned down the driven pulley on the saw spindle to a much reduced diameter, and had been using O rings instead of the Dremel belt.
Can anyone tell me the dimensions of the original pulley? Most importantly, I need the running diameter and the width between its flanges so I can make a copy, as replacement parts (other than the belt) are almost impossible to find. The manual is readily available from various sources, but it does not give any dimensions.
Thanks -
Andrew
Thanks -
Andrew
