Loco
The Massoth (Mammoth
) Navigator is a nice controller for the MTS3, I have the same setup myself.
However, there are some limitations when the Navigator is used with MTS3 and they are listed in chapter 1.1.3 in the manual. The issue is the last limitation with automatic function routines whichincludes consisting (and automatic operation etc.).
I have to correct myself, consisting does work and here's how:
1) Go to the Menu (M3)
2) Go down to Automatic Progr. and press M2
3) Go down to Consist Progr. and press M2
4) Input values for Number (which is the consist adress) and the loco adresses to use in the consist and press OK
5) When back in the main window select Menu (M3)
6) Press M2 to select Consisting
7) Use M2 to select the consist number and confirm with M3
8) Run....
8) Run....
