I have been very busy of late but I am gradually working my way through the various modifications and cosmetic improvements to my coal fired Ragleth. Most obvious one at the back end is replacing the standard Accucraft reverser with a modified early Roundhouse reversing quadrant. What it does mean is chopping the top off, reversing it and silver soldering it on again, because the Roundhouse jobbie is designed for the port side of the loco. new holes in the lever have to be drilled for the Accucraft 'reach rod' and to allow flexibility of timing. At the front end i have fitted roscoe lubes, blackened steel handrails, lamp bracket and the pipework for the vacuum. The buffer beams are still to be done (rivets, vac stands. safety chains and sprung buffers) and I am just completing the work on the bodyshell. No pics for this yet, but more blackened steel handrails, a swift 16 toolbox ? the bunker has been moved to the port side as well and has the gauge O coal removed so I can use 'proper' size lumps.
