bobg
The word ?Whiskey? is a coruption of the Gaelic for ?Water of Life?, forget the ?of life? bit, all we?re distilling here is good old H2O! The tax man might be logged on.
Further to my promise in post #36 in http://www.gscalecentral.net/tm&m=61152&high=Solar+still&mpage=2 < Link To http://www.gscalecentral.net/tm&m=61152&high=Solar+still&mpage=2 < Link To http://www.gscalecentral....olar+still&mpage=2 I have (at long last) completed a solar still, roughly as per the design on the website http://www.motherearthnews.com/Renewable-Energy/1974-09-01/How-To-Build-and-Use-A-Solar-Still < Link To http://www.motherearthnews.com/Renewable-Energy/1974-09-01/How-To-Build-and-Use-A-Solar-Still < Link To http://www.motherearthnew...Use-A-Solar-Still quoted in post #34 by Thumper, so I make no claim on originality, nor even to finding the original info.
I liked the idea because it looked to be effective, and more importantly, free to run. My contribution was to be that I would try and build it for nothing as well, and I very nearly succeeded.
It took me a couple of weeks of searching and scrounging to find what I needed, the most difficult was a piece of glass that was big enough.
Materials
Glass 17.5? x 24?
19mm Plywood 18? x 25?
Square-line plastic gutter 25? Round would do.
Plastic waste-pipe 1.5? x 25?
Plastic ?L? shaped facia cover board 8? x 70? approx.
Large handful of wood screws, various (used)
Small steel angle brackets (used)
Timber 1? x 1? x 18?
15mm copper pipe 26? x 2off
15mm end caps x 2off
Ice cream tubs 2off
Silicon sealer
Kitchen foil
P.V.A. glue
and the one point where I did get stuck??
Black hand-towel (purchased from Dunelm £1.99p), I suppose any colour would do really, but black is supposed to absorb the heat.
Most of the above I had laying around from previous projects, some I acquired from ?other? sources. I suppose in the truest meaning none of it was really free, just surplice to requirements, but the outlay for end result was just £1.99p for the towel.
Construction started by cutting the frame pieces to size, length and width (of the gutter). I reduced the overall size from ?bath towel? to ?hand towel? for two reasons, the size of the free glass and I thought that I didn?t need anything ?that? big.
I then cut the back-board and after cutting the groove, gave it two or three heavy coats of 50/50 outdoor P.V.A. all over. Selecting the best side I gave it another coat of 25/75 P.V.A and applied the foil leaving a sensible over-lap all round, which I then folded and glued carefully to the edges. The tricky bit was trying to get the foil to go into the groove without it ripping.
The main box is simply screwed together onto the edges of the back-board, and I added two small angle brackets to hold the front top corners to aid construction, rather than final strength. I applied no sealant here to allow the back to be removed for maintanence/cleaning.
I cut the waste pipe in half, length-ways, to form the inner trough to catch any over-flow from the towel, and cut two end pieces to fit the gutter with cut-outs for the waste-pipe, one slightly deeper than the other.
Those end pieces were stuck into the box with silicon sealer, using the gutter to find the position. When set, the trough was added (silicon) and a hole drilled through the box at the lower end of the trough to complete the over-flow. And the gutter was glued in place (silicon again).
The one tube was drilled No 50 holes at right angles as described in the recommended ?Mother Earth News? website and sealed at both ends. A 6mm hole was then drilled in the top of this tube. This was to suit my chosen method of water supply.
15mm holes were drilled over the centre of the trough, ensuring that they were level with the top of the box (important). The towel was washed and sewn into a loop, and a second set of 15mm holes drilled at the top of the box at a sufficient distance to ensure that the towel was held as tight as possible without stressing the tubes into a bow shape.
The required angle for the unit in the UK is around 60deg so I fabricated a tapered mounting for the water supply tank (ice cream tub!), and a rear strut (1? x 1?) to suit. I chose the ice cream tub because the lid didn?t form a seal, alternatively a small breathe hole could be used.
Final assembly required the removal of the top panel; and the glass, suitably siliconed on three sides; was placed carefully in the box, the box top was then replaced. When cured it was turned over and a bead of silicon fed round the edges of the glass, taking special care with the edge that met the gutter. The top corners of the box were also sealed. And a 6mm hole drilled in the opposite end of the gutter (at the back) to the overflow. This is the collection point; I used another ice cream tub for that.
Initial trials are not exactly exciting. The first day was quite dull and it took about an hour for the glass to start dripping, regulating the water flow to the towel seems tricky, too much and the towel drips causing the overflow to loose water, too little and the reservoir seems to stand still and you wonder if it's doing anything. I used a rolled up piece of "J" cloth pushed into the feed pipe as a filter/regulator, adjusting the flow by pushing it deeper. Water does DRIP out of the collection hole, but very, very, slowly.
We await a better, sunnier day.
Any further progress I will report on here.
Materials
Glass 17.5? x 24?
Ice cream tubs 2off
Silicon sealer
Kitchen foil
P.V.A. glue
