I am in the process of working out the wiring for my tender mounted headlight. Obviously, I only wish it to illuminate in 'REV' direction. The problem is that I only have five wires in total to connect the tender to the loco mounted decoder.
Two wires are for track power. Two wires for the speaker leads. Only one wire is leftover to operate the tender headlight. I was thinking of picking up the track power (right rail) from the tender pickup (inside tender) and then, using the remaining wire on the connector, feed the negative return to the decoder function terminal (left rail?). My issue is if polarity changes on the rail during loco direction change, will this affect the decoder, or will status quo remain in place as I would think the decoder 'polarity' would be the same as the track polarity?
