Hi Gang, spurred into action, following several conversions with "The Marmalade Boys" several suggestions were put forward, the fruits of my labours for the last three or four days.
Track base made from Block Pavers suitable embedded in a mortar mix, more or less level! Infill with 20mm gravel, bit over the top, but as Wickes doubled the Dumpty bag order for gravel ( free & gratis) had to put it somewhere!
Conventional roundy roundy, incorporating a Wye for additional train movements, took three attempts to get the correct alignment and geomentary correct, worked out first time on the kitchen floor, but would it fit into the real world, nope never in million years, much faffing took place to get it to fit, eventually!
All fishplates were given a smear of Copper Ease, boy this really does make life easier connecting the track sections together. Rail clamps incorporated at strategic intervals, for connecting point decoders and acting as a back up to preempt any failings with the contacts on the LGB points ( noted from several posts on here).
Should be making the timber supports for part of the loop which is balanced on a Heath Robinson contraption at present, instead spent several hours playing trains, sorry that should be testing!
Lots more to do....... but Up and Running in Exeter at long last.............
http://vid1157.photobucket.com/albums/p581/Eaglescott/die%20Eichel%20Bahn/die%20Eichel%20Bahn%203rd%20May%202015.mp4
