beavercreek
I am a very new wet behind the ears user of DCC and the following is probably a real 'no-brainer' for you experienced guys but here goes.....
I have a centrecab which has a Massoth XLS decoder . It works perfectly fine on DCC but will only work smoothly (motor, lights or sound) at higher voltages about 12 to 15 volts and up when on DC.
At lower voltages the lights, sound and motor keep on turning off and on. I have tried this with different DC powerpacks on extremely clean track....same problem whilst DCC remains perfect. All DCC functions operate absolutely fine.
I know that there has to be a 'wake-up' voltage but was not aware that it would be so high
There is no smoke unit
Does anyone have any ideas as to the cause?
