Wobbleboxer
I need some help with a DC wiring puzzle that I seem to have created for myself. Not your normal reverse loop question.
My line is basically one big loop, with sidings off, very familiar to most I'm sure. My plan is to extend a new loop off the main one into another area of the garden. The attached picture will hopefully help explain.
Now bear with me cos this is where my brain starts to overheat.
A train running west to east on the mainline will pass through point C and point D, no special wiring there.
Now consider a train entering the new loop from the west via point C. If the centre link is wired to take its power feed from whichever link point B is pointing at, then the train can enter no problem. Further, if the loop is wire to take its power from the centre link, then point A can be set either way and the train will enter the loop.
However, in order for the train to exit the loop point A must be changed and in doing so the polarity will change. But if point B is changed simultaneously it will also change the polarity of the centre link and in theory the correct polarity will remain for the train to continue it's journey and exit back on to the main line via the right hand link. A brief stop in the loop should overcome any jumpy trains caused by the brief power switch, but I was planning a station in the loop anyway.
So long as points A and B are changed as a pair I see no problem here. Or have I got this all wrong?
