dutchelm
A simple job, fit a decoder in to a LGB 22355 maintenance tram. Direct decoder so just plug one in.
First problem was getting the 8 pins into the very tight sockets, extreme force required, even after sockets had been opened up a bit.
Then program the decoder, a few problems here as the MD decoder was different to a Massooth decoder but sorted.
Then the test run. The tram ran fine on DCC but went backwards on DC. Normally I can swap the track wires on the decoder but it is plugged into the main board & fixed . If I reverse the motor it will fix the DC but then the DCC will be reversed, likewise if I change bit 0 on cv29. If I swap the pickup wires on the motor block it means the track doesn't line up with the trailer plugs on the cabs.
Am I missing something?
