CV 1, CV2 how do I get this
Dinas Bryn
Afternoon I have a single LGB point switch I understand what I am to do but how do I get the CV with a hand control Les
I guess you mean the LGB 55024 single channel point decoder here Les?
Instructions are here;
http://www.champex-linden.de/lgb_pr...17C5C985257141004BFB06/$FILE/55024_042006.pdf
They don't seem too clear but I assume you have to program it the same way as you would a loco on a programing track with a LGB 55015 Universal Remote using the programing plug-in, connecting the brown and white wires to the two pins on the LGB 55024 unit and the green and yellow wires to a siutable power supply like the LGB 50110 5A unit.
If needs be, you can PM me for my address, post it to me and I'll do it using the MTS PC 6.0 program on my laptop....
Morning now I understand I have got a unit for changing loco numbers I will dig it out we will have a go if all fails I will get back to you. many thanks Les
Afternoon I have found the unit and done as told I will have to wait till it stops raining before I can test it on the point, many thanks les
PS have tried the unit this morning it didn't work so will redo it later Les
PPS reprogrammed it went ok, failed, removed the motor and brought it indoors worked fine, put the decoder on another point failed, will pm you Gissy if you think it is worth it Les
