CoggesRailway
How do I do it? I am OK with ruler-knife-bend-until-it-snaps but if I want to cut a curve? I don't mean heating and bending a sheet - actuall cutting a curving edge.
Ian
Ian
CoggesRailway said:Thanks steve possibly but would the plasticard just break as normal?!
I have made a very basic disk sander using an old washing machine motor and wooden disk withCoggesRailway said:How do I do it? I am OK with ruler-knife-bend-until-it-snaps but if I want to cut a curve? I don't mean heating and bending a sheet - actuall cutting a curving edge.
Ian
David Jenkinson mentions this problem in one of his books and proclaim a "french curve" template to be the solution:yb281 said:Of course the drawback with compass cutters etc. is that they're fine as long as the curve you want to cut has a constant radius, the problem comes when you want to cut a compound curve. Then things can get VERY tricky. A lot of roof profiles, for instance, have several different radii - especially the old Southern Railway designs.![]()
ge_rik said:I use the same method as Mel - ie a few light scribes along the curve, and then heavier cutting strokes - and then a bit of Dean's approach. I tend to cut just outside the intended path and then finely adjust with a piece of sand paper/emery
