JimmyB
Though my Locos are battery, I use DC to power my points (turnouts), and am about to re-wire my track for this. Previously I used 20 mm solid conduit and fittings and threaded single wires (as and when required), however for this re-wire I am going to use and 8 wire bundle (2 off) which should provide sufficient connections, however this is a tight fit in the 20 mm and was considering using 25 mm conduit. I see that some of you use flexible conduit, and had previously dismissed the idea, due to the wires, possibly snagging on the inner walls. So will the wires thread easy in flexible conduit, or should I still with the 25 mm solid and the inspection corners.
Many thanks in advance for your advice
