Chipping an old 2 pin motor
NigelP
So I have an old 2 pin motor that I want to chip.  Is it as simple as connecting the green and yellow wires of a 55021 to the pins and the brown and white to  the tabs on the motor and ensuring no contact between the tabs and the pins any longer (e.g. be reversing the motor unit) and worms?
Apologies if this has been asked before but can`t find it in old threads.
TIA
Nigel
Apologies if this has been asked before but can't find it in old threads.
TIA
Nigel
NO!!!!!!!! :-[
I don't know if you meant to put it that way round or not, but you'll blow the chip if you do it as you've written it.....
The GREEN and YELLOW wires go the the MOTOR TABS, the BROWN and WHITE ones to the TRACK POWER (ie: the pickup pins).
The rest of your post is fine - as long as the motor is fully insulated from the power pins, then it is that simple. ;)
I've blogged it here if this is any use
http://riksrailway.blogspot.co.uk/2010/11/fitting-decoder-to-grs-hunslet-kit-on.html
Rik
Zerogee said:
Nigel
NO!!!!!!!! :-[
My memory fails me, but at least I sent the correct linky for the 55021 Jon....
