Change language on massoth navigator
Graham
In Smoggy Land
For some reason I can't work out how to change the language on my navigator. I bought them from Holland so they are not set to English and the manual is not too helpful o_O
Firstly - you can only access languages that are already in your navigator. English is usually there as far as I know. New languages can be uploaded if required. i would ask a dealer or an experienced operator to do this.
From the begining, Press button M3 labelled MENU, this opens the MAIN MENU. Using M1 button select NAVIGATOR KONFIG and OK with M2. M1 down to CHANGE LANGUAGE - but you will probably see the German - SPRACHE WECHSELN. Press M2 to change (It should go straight to English) save with M3 which takes you back to the start.
As Alan says, the Navigator can have two languages installed and you can switch between the two as he has detailed. If English is not installed then you will need to update it with the English language as either the main or secondary language. The Massoth Service Tool is required to do this via a DiMAX central station or a PC module.
If you cant find anyone to do it for you then I can do it at no charge except the return postage.
