A
Alec K
Guest
Getting there, very gradually....
I decided to award myself a birthday treat and took advantage of a rain-free hour to assemble a 'local' train. It's the first time that the scratchbuilt Redlake Tramway coach and Lee Moor Tramway water tanker have run together and I think they look 'about right'. Given that the former prototype ran on 3' gauge and the latter on 4'6" gauge, that's quite surprising, but at least they both have a mineral line heritage.
I cured a long-term fault with their motive power last night: Lady Pamela, the 'OTTO' loco at head of the train, has not run smoothly from new, having suffered from a slight but marked lurch on every full wheel rotation. I used the LGB workshop diagrams to disassemble the loco, removed the motor cover and found that the worm gears were lifting slightly out of mesh with a change of direction. The inbuilt clamping supplied by the motor cover was not firm enough. I cut a piece of firm foam packing to fit immediately above the motor in the appropriate recess, then refixed the cover. Problem solved - I now have a smooth running and powerful little engine.
I also noted that the workshop diagrams show the dome/safety valve assembly and the sandbox assembly in the opposite positions on the boiler to that in which they were supplied from new. In fact, every OTTO picture I checked showed that the factory fixed them in the opposite order to that shown in the workshop manual. So my loco is now correct per the manual - and probably prototypically wrong! Unless, of course, someone on GSC knows better....
Best wishes,
Alec K
Best wishes,
Alec K
