Brake gear
ge_rik
As I'm plodding away replacing all the LGB style couplings on my stock, I've started adding cosmetic brake gear to some wagons to relieve the tedium. Some of the ex-LGB wagons have representations of vacuum braking systems so I've removed the cylinders and all but two of the brake blocks and then added a representation of a manual system. Tried a couple of techniques using brass or plastic. Clearly, the brass will be more robust, but the plastic is a bit easier to manufacture.
file.php
file.php
Not very pretty but once painted and the wagon is up the right way, I might be able to get away with it...
Rik
Looks smart, will definitely all come together with paint. Another idea to take more inspiration from (shamelessly copy) :)
