Bodging Lionel Thomas pickups
Chris Vernell
45.29 N, 75.75 W
Lionel's 0-6-0 chassis, as used in Thomas and James, has unreliable track power pickups; at least one of the four invariably fails to make contact with its wheel, with the inevitable results on plastic frogs and dirt spots ("Mummy, why is Thomas stopped?" :banghead: :swear:).
A year or so ago, I installed LGB ball-bearing pickup wheels under James's tender, connected to the loco by plug and socket. The improvement was remarkable: no more jerking on dead frogs; the loco is much more responsive to subtle changes on the regulator; slow running is possible. (I put a voltmeter on Thomas before I changed the wiring today, and found a notable voltage loss between controller and motor.)
So now I have got around to Thomas, using the BB wheels under Annie. Thomas works nicely on the test rollers, so I have high hopes for running on the line.
Lionel put a strange grey box in Thomas's cab. I was never sure what it covered.
It turns out the box covers nothing, so I sawed the top off to allow easy access to the wiring.
Cut a slot in the rear of the bunker for the extension wires.
Lionel allowed plenty of slack in the wires connecting the pickups to the motor, so it's easy to solder on an extension.
Drilled holes in Annie's swivel truck plate and ran the other extension through them.
Wiring underneath Annie. The loops are there so the trucks can swivel freely on our R1 curves.
Connected, with Thomas on the test rollers and running nicely.
And so two engines with well over 20 years' service at train shows have become even more useful. The Fat Controller approves.
You have done a good job there. Those locos are now over 20 years old, and were never that well built. To keep them going at all is amazing.
Children loved them and particulary like the eyes and changeable faces!
I never owned any, but a chum had a pair, which he would bring to events and run on our layout. The owner of a local model railway shop and display had some too. As I recall the chassis mechanisms were common to other Lionel models and there were often gearing failures. The chaps would buy other chassis to cannablise to keep Thomas and James going!
The models were never officially imported to the UK, so are still a little thin on the ground here. I think that was because at that time Hornby had exclusive rights to Thomas with thier 00 series. Maybe they are more common in Canada?
'As new' ones were going for crazy amounts at one time, but the prices seem to have rather dropped off after the Bachmann ones arrived in late 2009.
Well done once again.
James
