I jumped on the blunami band wagon was an easy install and everything worked well.
Then I turned the headlight on and I got distortion from the speaker. Turned the light off and sound is perfect. I tried another speaker same thing. Changed the light setting to led same thing. Moved my phone a distance away from the engine same thing. Running on the track you can't here the distortion but it is there.
Any suggestion on a setting I can try?
I'm using a visaton fr7 8ohm speaker.
Thanks
Thanks
