WKDOR
After five years of trouble-free running I have a head-scratcher of a problem with our most reliable Battery/RC powered loco - a very elderly LGB Krok.
Power is from two sub-C battery packs (6-cell and 8-cell = 16.8v nominal, overcharge = 18v). Control is a Railboss ESC, RC is Deltang, Sound is Phoenix P8. All stable for last few years.
Until now. On power up the RC connection is OK and Phoenix startup sounds start OK. The battery voltage measures 18v but the power to the ESC measures only 14v. As soon as I start turning the throttle up, the sound dies and the motor trucks turn only slowly. Voltage supply at the ESC and Phoenix card measures about 5v, whereas the battery still measures 18v.
The only item between the battery and the ESC is a small battery conversion module which is a switched and fused set of screw terminals:
http://www.gscalegraphics.net/uploads/2/5/7/7/25776635/bcm2_manual_a.pdf
I have replaced the fuse at 5A but that made no difference.
The loco has been in a recent collision!
What am I seeing here please? All suggestions as to possible cause or further diagnostics will be very warmly welcomed.
mike
Moderators please move if this is better under Battery RC
mike
