Battery control Wagon, Multi use, multi power, Multi loco
Granitechops
Narrow Gauge 1/12th scale on 45mm</br>Quarrying &
Just been doing some more work on the second battery control wagon,
so thought I would first bring over the start of this project from GSM
DATE check JUNE 2009
As some may have noticed I often recycle everyday items for railway use
but today I departed from the usual; as I saw something that was still in use & NOT ready for recycling yet
A bin out of an accessories carry box
Figuring that they frequently never returned to the carry case,
I though how useful it could be to turn it upside down
Drill a hole for a forward /reverse switch
& two more for the power out to the jack plug for connecting to whatever loco would be in use
Including wires & connecting jack for power in from a 7.2 vlts battery pack as an alternative
Power in leads connected to a couple of AA cell holders Making 12 cells
needs a speed controller, but that is not to hand as yet.
This is just in testing mode
it needs a power jack on front of wagon
jack sockets at rear of each loco
covers for the batteries
A fuse in the circuit
a speed controller
but for now its working
Insert jack socket to check clearances
Would have liked to put it down inside that central raised floor area but there was not room in there
and a smaller jack would have meant more problems with seeing what I was soldering
So cut off flexi part of socket cover
Not critical as it does not get any pulling strain in here
wire up & fit
leaving enough wire curled up, inside for any later dissembling of Loco
Set up
needs a bit of black tape around end of plug to hold wires securely
And with hind sight
it would have been better to have the wires exiting the wagon ABOVE the buffer beam
although after 3-4 hours track testing, it has not fouled on the couplings yet
Poor pic of T Urn going over Gotha pool bridge
the blue wire is purely cosmetic, it represents the Air brakes coupling
<p> </p><p>So now I can fit any small engine with a jack socket, </p><p>& run it behind this wagon </p><p>AND if I get round to making another different wagon, </p><p>with say R/C I can ring the changes, </p><p>so the same wagon is not always behind the same engine </p><p> </p>
7.2v disconnected FIRST
before filling holders with 12 AA cells
These cheap LIDL rechargable AAs give quite a good run, even including pulling 20 wagons up a 1 in 20
but no good for the camera thou.
Note;
there are battery holders & there are Battery Holders
The 8 cell holders ( from Maplins )are simple to get the cells out of
The 4 cell holders( from else where ) are a pig, need a screwdriver to get them out,
