KeithT
I almost had a catastrophy with the K27 a couple of days ago. It had been running for a couple of hours but a storm threatened. Whilst I am OK about LGB locos running in the rain I find Bachmann less amenable. For one thing bits can go rusty after no more than heavy dew.
So, I stopped the loco under a wide bridge and placed a plastic sheet to cover the projecting 'bits'. After the deluge had passed I removed the sheet only to discover a small hole had allowed water to drop on the 'coal' in the tender. This is a rectangular insert allowing access to the electronics. On lifting the insert I found that there was a small pool lying in the well around the large opening allowing access to the circuit board. Fortunately, there is an upstand around the well but it showed the vulnerability of the electronics to water penetrating the tender.
To avoid any accidents in the future I intend constructing a cover to prevent water dropping directly onto the board. There is a slot to the front of the well which would allow any water falling into it to drain away before it tops the upstand.
A narrow escape though. Usually, when rain threatens I remove all Bachmann locos from the track. In this instance I was expecting a visitor and did not want the hassle of lifting 'the beast' off and then back onto the track.
