True, weight behind the drawbar is weight behind the drawbar. But if I can keep it in the tender I don't have to haul another car with me all the time with the batteries in it; that can be replaced by revenue load. I will of course lose some hauling capacity by adding weight in the tender unless Neil's weight addition comes through with increased adhesion.
So far I've only had a cursory look at whether it would be better to put all the electronics in the tender but I will be exploring it further. However, even doing that (and I'm not sure for heat reasons I can in fact put them all in the same place, remembering I'm going to be adding a receiver and ESC) I'll still only have space for a reasonable number of AAAs, not AAs, as I presently see it - that boiler is small! And, in particular, it is obstructed by mouldings to receive the screws which hold the boiler bottom moulding on.
BTW, before somebody asks, the layout of the boiler is such that if I have to I can add unseen ventilation holes in its bottom which will receive a level of, well I can't call in forced draft but you get the idea, from the wheels in motion. I measured the air flow off the wheels with what I could wistfully describe as a homemade mini anenometer (although that child's toy with the plastic propellor on a stick you get from agricultural shows in Australia was what it was mostly like and where the inspiration came from) when I was first thinking of doing this. Now, that was a perfomance it itself and it's something I would never have thought I would be doing, it's marvellous where this hobby leads sometimes! It also confirmed my wife's belief that I'm nuts when she caught me puffing at it to provide a rough calibration. If that doesn't provide sufficient airflow, and I think it will, there is also potential to add air scoops.......
Steve
