Bachmann Conso Tender Body
Don Gilham
Model railways, Photography, anything lazy
Probably a very looonnnnnnnngggg shot, but does anyone have a spare Bachmann Conso Tender Body by any chance ?
Thanks
(or complete tender, but that's me being greedy)
Thanks
Don
Have you got a pic or link to one, of type you are after
I have a few box's of tender bodies and bits, came with some gear i bought
a while back
[font="arial,helvetica,sans-serif"]Hi Rob[/font]
[font="arial,helvetica,sans-serif"]What I want to do is to give my 2-6-0 a bigger tender, so a larger body that would fit on to the chassis would be ideal. The chassis size is 240mm x 95mm maximum, so I guess an ideal body would be about 220 x 90. Any heifght above 60mm would be good too.[/font]
[font="arial,helvetica,sans-serif"]I hope this helps - and thanks for getting in touch[/font]
[font="arial,helvetica,sans-serif"]Don[/font]
You might try gluing on an inch of styrene, or scrap tender around the bottom. works for me. Here is an Annie tender "biggerised"
Connie tenders are a bit on the wide side, what 260 loco is it ?
Rob that looks fantastic !
I've had a look and mated my Conso tender to the Mogul (having been prompted to do so by Jonathan - thaks Jonathan !) - yes it's wider, but matches very well - and as there are examples of wider/narrower tenders being used prototypically, that'll do for me !
So now I need to get an Annie when the new one appears later this year, and have a go at conversion as you have done. You must have increased the size of the cab too - and I love your rivet work !
Please elucidate (if that's the right worm) :bigsmile:
Excellent, Rob, thanks !
Now to delve in to Smegworld....yeeuuuwwwwwwww !
Hope you don't mind, but all that's saved Rod (why did I call you Rob ?), because my tiny brain can't cope with too much at a time !
Love the conversion though, has my blood up and running !
