darkdaniel100
Hello folks ... Bit of a random request! Could someone post a picture of a side by side comparison of a 1.20.3 boxcar next to a 1.22.5 version?
Cheers,
Dan
Cheers,
Dan
darkdaniel100 said:Hello folks ... Bit of a random request! Could someone post a picture of a side by side comparison of a 1.20.3 boxcar next to a 1.22.5 version?
Cheers,
Dan
funandtrains said:It is a bit more confusing as the cheap Bachmann boxcars seem to be 1:24 and are smaller than the 1:22.5 LGB and USAT versions.
Richie said:Have a AMS reefer in top photo and Bachmann reefer in bottom pic taken same location on my line if this helps .
One of the things that looks OK, is to run the 1:20.3 cars at the front of the train, and follow these up with the 1:22.5 stock. Both Spike and I have done this. I blew it when I bought a 1:20.3 caboosedarkdaniel100 said:Cheers for responses , I was just interested to see how the cars looked together ... I was thinking about mixing scales together but I think that they will look alittle odd !
Probably slowly replace all my smaller items with 1.20.3 rolling stock ! Cheers
The Devonian said:................. were Bachmann Big Hauler stock, quoted as 1:22.5 and sometimes mistakenly as 1:20.3 ...........
The Devonian said:
Subsequently graduating to 1:29 stock I quickly realized that the two scales sat harmoniously together, in my opinion, particularly as the smaller Bachmann stock was smaller than the 1:29 as it was in the 1:1 railroads.
funandtrains said:Rhinochugger said:The Devonian said:................. were Bachmann Big Hauler stock, quoted as 1:22.5 and sometimes mistakenly as 1:20.3 ...........
Part of that confusion was Bachmann's own website. However, to further demonstrate that the 1:22.5 boxcar may not be all bad, I've borrowed one of Cyril's (Glengrant) pictures.
The K-36 and K-37 locos were the largest fixed wheel base locos ever made, with only the Garrets and Kitson Meyers supplied to South America being larger, they were as large and powerful as LNER A4 pacifics. I've attached a photo of my Kiss K-36 which is 1:22.5 scale next to LGB coaches and you can see how small it makes them look. It is a similar size to my Bachmann K-27 at 1:2.3 scale and is too wide to fit through LGB 600mm long girder bridges.
