I decided to build an Auto Trailer in the style of the GWR AutoTrailers. Obviously the GW prototypes are standard gauge and I am modelling something like 16mm scale on 45mm gauge. I excuse this by imagining that the railway being modelled is an offshoot of the GW and looks to them for inspiration for stock (I've previously built a Railcar). That allows me to build something which I hope evokes the spirit of the prototype without needing to slavishly copy it. For starters I limit my coach lengths to just over 50cm, which is the length of my Brandbright VOR coaches which work a treat on my line. I had quite a lot of R1 curves, although I've recently eased all those on the mainline to a mixture of LGB R2 and Trainline R2.
The limit in length means straight away that the coach will be a shortened version, so where the prototype would have four passenger compartments I'm only having two. I've also opted that the non-driving end will be straight rather than curved like the driving end.
I'm using Obeche wood to build the model. It's a very workable material, significantly stronger the balsa, but easier to cut than ply. It comes in various sizes of small strip and very convenient 100mm wide planks which I use for the sides and base. The chassis is 3mm thick enforced by 10mm square frame. The sides are 1.5mm timber which makes cutting the windows out easier - although the sides do end up with three thicknesses of timber to allow the windows perspex to be sandwiched in between.
I started by drawing up the panels in CAD on the computer and then printing these out which make templates which i taped to the wood and then cut the windows and scored lines for the doors. The windows have a 4mm hole drilled in each corner and I then cut between them. Here are some examples of the templates:
I'm around half way through the build. The main bodywork is in place as is the interior with the exception of the driving end. I've done this because I have a pair of brass rods to slide in the top of coach to which I will solder the interior lights. However once the front end is built the rods won't come out again.
Next up is to fit the rods and then build the drivers end of the coach, body and then interior... I'll keep this thread updated as I progress if folks are interested. In the mean time here are some pictures of progress so far.
