Martino
....(see the post in General G Scale) I did some experiments and started some planning. The result is some questions which some kind soul(s) may be able to help with. First though, excuse the rambling but it's helping get my mind clear.
The scenario:
I have an end to end track that runs round the edge of the garden. It's about 250' from one end to the other.
I have a Digitrax DCC set up.
Up till today I have had one power feed located mid way along the 250'. 99% of my rail joints are either split-jaw or Accucraft brass rail joiners, so I virtually never have any power breaks. I've also not experienced any noticeable power loss or drop off. I do have some issues with the sound on locos fading every now and then, but this appears to have nothing to do with the distance from the power feed (as I proved this afternoon).
Anyway, I experimented with attaching the power feed at either end of the track. This seemed to have no effect on the way the locos performed or anything else. It would be easier for me to have the power feed at one end (see later).
QUESTION 1: Am I likely to have power drop off issues by having one power feed at the end of the 250' run? Is there a formula for working this out? Would any voltage drop be significant.
Next issue:
Currently I have a moveable control box that I set up on my patio (near beer, tea etc) which is about midway round the line. I have a radio control transmitter attached to the box. My radio control throttle (admittedly a cheapo Digitrax one) appears to work not perfectly, and only in line of sight. I believe that the newer throttles have better range and aren't worried by line of sight.
My thought is to put all the control gubbins in my garage at one end of the 250'. That's why I'd prefer to have the power feed at that end. Then run a CAT 5 cable round the house, with Digitrax plug in modules at strategic points (suitably weather protected) and maybe three wireless transmitters hooked in also at strategic points and suitably weather proofed.
QUESTION 2: Am I totally Mad? (rhetorical question)
QUESTION 3: Will it work?
Thanks folks, in advance
Track plan is below.
The scenario:
Next issue:
