Hi Mike. Did the Mikado and Pacific share the same moulding? If so, I might just have one in the garage somewhere. Don't hold your breath - I will try and find time tomorrow to conduct a search.
Mike. (Another one).
Many Thanks Neil.
Yes I entirely agree with your first sentence - the newer Pacific is different from the older Pacific chassis and they're both different from the Mikado.
But my edition of the Aristo Exploded Parts for the Mikado shows part # as 21400-33 Chassis. It has an ID under the page number of 071003 that I guess is the date. Could you check this ID on yours please? Can I have a copy?
Best
mike
Many Thanks Neil.
Best
mike
Yep, the Mikado and the Pacific shared the same chassis. In fact due to similar mouldings for the the boiler etc, some have called it the 'Pacifikado'.
The motor and gearing gear were changed so that each axle has its own gearbox and flywheel and I am not sure if it was done at the same time on both types of loco.
I have a Mikado with one broken gearbox (both of the wheels and axles have separated from the gear itself).
I am hoping to get a spare gearbox/axle assembly from Navin when I go over to New York at the end of the month (I have already spoken to him about it so he does have one,... but only the one, apparently, that he has put aside for me!).
Many Thanks to both.
Yes Neil that's the same version I have. I agree that using the model number suffix would be logical but that's not what Aristo did in the Parts list on page 6!
Ask and ye shall receive, hopefully. Well here it is Mike. Still has some pipework and tanks attached. I can't see any damage to the main chassis, but it's not pristine. As I don't have the motor block I didn't know where to measure from, but was a little concerned as there is a rebate for a driving wheel centrally which made me think Pacific. There is no obvious part number to refer to. If any good, it's yours for a tenner including postage. It would have been less but it's too long for a small packet so will incur medium parcel rate.
View attachment 216945 View attachment 216946 View attachment 216947 View attachment 216948
Back to the drawing board I'm afraid Mike. It's 200mm between the points marked, not the 220 you desire. Sorry I can't be of assistance.Many thanks for speedy reply Mike. Sorry for delay Can't upload with FF again.
Not pristine is fine by me. Can you please measure between the motor block mounting posts fore and aft, something like this:
Many Thanks
mike
Good luck with your search. Regards Mike.
