Thanks Peter, that answers the question on what the MLS needs.
Still would like confirmation on how many AAA batteries he is using, but the Piko does say 6 AAA batteries.
So now we want to pick a boost voltage that will keep the loco running the longest, and if you really wanted an estimate, you would look at the discharge curve of the batteries, which in this case is worse than nickel metal hydrides.
But the missing data is the amp hours of the batteries.
- A standard alkaline AAA battery is: 0.86 to 1.1 amp hours.
- But a NiMih AAA is about 0.4 to 0.6 amp hours...
So the rechargeables have about HALF the energy.
Now hopefully even Jimmy will understand my concern, you have
half the run time if you do
NOT boost the voltage (and it still not working).
To further support my engineering "view", the OP states that the thing only works briefly.
So, the assumption is that he is pulling so much current the voltage drops too much with fully charged batteries. (makes sense)
Therefore you would set the boost module to output 9 volts, and it would probably (under load) be getting about 6.6 or less volts....
this is
really going to cut into the runtime, and this is where I was going, you are trying to boost the voltage roughly 50% so you could easily make the argument you will cut the run time about 50% using this setup. Since the batteries also have 50% of the capacity of the alkalines, that will further cut the run time.
So I would say that your runtime should significantly change if you add the boost module, to half or less the runtime you have with alkalines.
The bottom line:
- Is cutting your current (alkaline) runtime in half or worse ok? If so try the boost module.
- If not don't waste the money and time (although it is cheap)
(Jimmy, you need to read more carefully, he has 2 issues, the loco not moving and the MLS sound card not working, so to know if the booster will work, you really should know about the current draw, you do not get something for nothing, i.e. you boost the voltage of the batteries, it takes MORE current the batteries will not last near as long)
(you gotta work harder to take a shot and make it stick
