Accucraft Black 5 plus RCS Battery R/C.
Tony Walsham
Here is the latest install I have just completed.
It is a superb Accucraft all metal electric powered Gauge # 1 Black 5, converted to battery power only with Planet Twister R/C.
As with most Accucraft locos the install is quite easy to do.
I started by removing the stock voltage distribution pcb in the tender as well as all the tender track pick ups. The motor output wires remained in the loom so that loco to tender connection kept the original plug and socket.
Then I glued a sheet of thin styrene to the chassis floor and then glued the Decoder pcb with the latest Planet Twister 4 channel sub miniature RX, to the styrene sheet.
The very short antena wire can be seen on the left hand side of the RX. Believe it or not the RX works perfectly well INSIDE the metal tender with no wire outside.
I glued two 6 x cell AA size ENELOOP hybrid batteries into the tender shell. One either side. I glued a small sheet of styrene underneath the top of the rear of the tender and glued the 3 amp PRO-3a ESC in place.
A small sheet of styrene was used to hold the # U-BIK3 installation kit assembly so that the ON-OFF switch, Charge jack and programming push button were accessible under the removable coal load.
A space was left for a smallish oval speaker as the owner may want to install a sound system at a later date. There is still plenty of room for a MyLocosound or a Phoenix P8 inside the tender.
Once it was all back together I took the Black 5 up to Gordon Watson's layout to check out operation and range.
Here she is on Gordon's layout.
As previously mentioned, considering the RX was buried inside an all metal tender with only gaps where the wheels protrude into the chassis, the range was at least 200'. I don't know why that is possible, but it just confirms my earlier testing with the same brand of Planet Twister R/C inside live steam locos.
That looks like the new Planet 5 smaller Rx, if anyone in the UK is looking for one over this side of the world! Nice installation Tony.
I can confirm all this 2.4ghz gear works well inside the metal boxes of our locos with the tiny aeiral....Faraday cage indeed!
Yep it is...just put one in the "pullman v51/52"....its only 4 channel but seeing as im only using one :)
Thanks Gents.
The Planet Part # is R4Ms.
Although that installation does not yet have sound, if and when it does there will be 4 x sound triggers available.
I have also been testing the New R7Ms. This required a modification of my operating program so that it would work successfully.
The right angle entry servo pins make life much easier when plugging in the Rx's to the decoder pcb.
If anyone reading this can let me now if the same Planet R/C equipment is available in the USA yet, I would be pleased to hear from them.
