dumpy said:This may be a stupid question but will ask it anyway.
Am looking to link points, signal lights and stopping trains. Have got all the bits but need a DC supply to operate some relays. Is the track supply from LGB MTS 11 DC or am I going to need a separate DC source?
Have you tried using a simple bridge rectifier to get a DC source from your track power? I use them very happily to get points to change automatically with reed switches. A W04 design rated for 1.5 amps/ 400 volts works well for me. Available for pence quite widely, or go to EBay. This is just one example: http://cgi.ebay.co.uk/W04-FULL-BRID...omputing_PowerSupplies_EH?hash=item20aecdf09bdumpy said:This may be a stupid question but will ask it anyway.
don9GLC said:... the DCC control signals, effectively a high frequency ac signal on top of the 'power' 50 / 60 Hz. ...
ntpntpntp said:don9GLC said:... the DCC control signals, effectively a high frequency ac signal on top of the 'power' 50 / 60 Hz. ...
Well, not quite ... there is no 50/60 Hz AC component, just the DCC waveform (at around 10 KHz I think). You'll sometimes hear or read the expression "the DCC signal IS the power" .
http://www.dccwiki.com/DCC_Tutorial_(Power) < Link To dcc Wiki (power page)
You should be able to derive a usable DC supply from the track via a bridge rectifier and a smoothing capacitor, as has been said in other posts. Be mindful of what you power with it though: - for example if you drive point motors from the track supply and there's a short that trips out the command station then you loose point power too. Some DCC experts advocate a separate DCC bus for point control etc. I've gone down this route, but more for the reason that I want to keep the pointwork operational while feeding analogue DC to track when I wish to run unchipped locos or use alternative controllers (eg. if a mate brings a Train Engineer round to play!)
Doug said:I would have thought that putting a bridge rectifier and smoothing capacitor across the track (to produce a DC supply for points etc) would affect the DCC signal to some extent, partialy smoothing it out.
whatlep said:. . .
I've been using the bridge rectifier arrangement quoted in my earlier post for a couple of years so far. It works. No ill effects to MTS Type 1, and Type 3 central stations, locos or associated LGB & Massoth chips, reversing loop modules and point modules, plus Bachmann, Piko and LGB motive power. Fair enough?
whatlep said:Have you tried using a simple bridge rectifier to get a DC source from your track power? I use them very happily to get points to change automatically with reed switches. A W04 design rated for 1.5 amps/ 400 volts works well for me. Available for pence quite widely, or go to EBay. This is just one example: http://cgi.ebay.co.uk/W04-FULL-BRID...omputing_PowerSupplies_EH?hash=item20aecdf09b
Obviously whatever power you take from the track reduces that available for locos, but if the items you want to power are remote from the DCC central station it may be an easy solution.
GrahamMills said:whatlep said:Have you tried using a simple bridge rectifier to get a DC source from your track power? I use them very happily to get points to change automatically with reed switches. A W04 design rated for 1.5 amps/ 400 volts works well for me. Available for pence quite widely, or go to EBay. This is just one example: http://cgi.ebay.co.uk/W04-FULL-BRID...omputing_PowerSupplies_EH?hash=item20aecdf09b
I am sorry to piggy back on this topic but I found it very interesting because I had not previously considered the issue that a DCC track supply is not DC. I knew of course but had not thought of the ramifications.
I have the problem that my knowledge of electronics is small and I would not know a Full Bridge Rectifier if I saw one and certainly not how to use it.
I run DCC through the track and I have a couple of points/switches on a remote part of the layout that I want to put under DCC control. I was intending using the LGB 12010 Switch Drive and the 55024 Switch Decoder to drive it. I assumed that all I needed to do in terms of power was to connect the 55024 to the tracks. Have I got that wrong and actually I need to get rectified?
GrahamMills said:I am sorry to piggy back on this topic but I found it very interesting because I had not previously considered the issue that a DCC track supply is not DC. I knew of course but had not thought of the ramifications.
GrahamMills said:Thanks Whatlep & Nico.
Nico - why did you go with USATrains #6 switches rather than Aristo-Craft?
Whatlep - I can understand the wiring. No idea why it works![]()
NO! LGB point motors are true motors (like Tortoise in HO/OO), not solenoids, so they need a DC supply. They don't seem to much care about the flavour, based on 10 years of use/ abuse. A simple, yet rugged solution if you are not yet into 55025s or similar would be to use a starter set controller and a pair of wires to each point via a "push to make" switch. Turn the controller in one direction or the other, press the relevant button and the point(s) will change. Changing the controller direction reverses your DC polarity for you, thus changing the direction the point motor moves. On my former layout, this arrangement happily shifted up to 5 points simultaneously for 6 years. No ill effects.dumpy said:(snip)So am daring to ask another probably ignorant question.
Upto going DCC everything was DC and I never thought about it. Now with a new season and my track emerging from the snow am rewiring using DCC. Do LGB switches operate OK with an AC supply (snip)
