tramcar trev
I have been toying with this for a while, install on of these in each tramcar: http://www.ebay.com.au/itm/Wireless...t=AU_Lighting_Fans&hash=item5aeb672467&_uhb=1
We have discussed these at length ad nauseum....
Ok so what I am contemplating is turfing my sectionalised setup and equiping each of my cars with one of these.
Pros - each car would be individually controlled, Overhead would be at a constant 12v 15amps, the pcbs are about 45mm sq if taken out of the case, lights would be consantly on while the poles are in contact with the wire and of course speed control and stop start. My colour light staff would automatically control single track sections.... Around 6 tram tragics could have fun at the same time...
Cons - NO reverse unless I can find some way of doing it individually for each car which when trams run into the depot which is a stub terminus they would have to be physically turned around for their next run but then the driver, eeer sorry motorman is physically stuck to the No1 end anyway. My trams would only run on my track unless I made trailers with batteries in them for them to tow around.....Each car would also need its own circuit breaker.... I'd have to find 6 tram tragics to play trams with me, imagine trying to control 6 trams with 6 keyfobs at the same time?????
At this price and I can get 6 of these for $10.50 Im thinking it may be the way to go, each keyfob would have to be kept clipped to its coresponding car and numbered of course....
Thoughts from the floor chaps?
Edited to add this thought;
Reversing could be achieved with a small DPDT switch discreetly mounted on each tram between the output on the wireless control and the motor....maybe a dptd rotary switch under the floor actuated by the brake handle would work.... or going to extreme what do you think of this 3 channel bizzo; http://www.ebay.com.au/itm/6Key-RGB...t=AU_Lighting_Fans&hash=item51a69c5c4b&_uhb=1 < Link To http://www.ebay.com.au/itm/6Key-RGB...t=AU_Lighting_Fans&hash=item51a69c5c4b&_uhb=1 < Link To http://www.ebay.com.au/it...m51a69c5c4b&_uhb=1
Obviously has one 12v output and controls 3 negative outputs so I could control the motor, sound effects and lights....
A challenge for me to work through I think....
