tramcar trev
Kero Lights?.
Having decided that I need a few Kero lanterns I decided to buy some. Yes well we all know where that went? The prices were through the roof and they had incandescent globes in them?.
If you really need it you make it yourself so I made some masters. These will be made into silicone rubber molds as soon as more rubber arrives from ALDAX.
The LED?s will be cast integrally and I?m toying with the idea of using flickering leds to try and imitate the flickering flame of a kero lantern?.. The handles are only there for illustrative purposes and will be individually fitted to the resin castings.
The Hurricane Lanterns is in 3 bits. The lens will be cast in clear material with a 3mm led embedded in it and will look good illuminated at night adjacent to the ?road-works? or hanging outside in the depot and per way yard?.
The square one is to be carried on all the trams as an emergency lantern and will also be used as a tail light on the steam tram trailers.
I can use any colour LED in these I wish but that depends on the final use.
Further updates when I get some cast in resin?. I could probably sell these on eBay... The smoke unit is currently delayed until the Nichrome wire arrives
