I have four of these track switches that I'm going to use at both ends of two separate shuttles. I bought them for using as a regular Reed switch. Here's my problem. When I check continuity on the terminal block common to normally open, normally closed to common, etc. I get no reading on my multimeter but when I check on the actual glass Reed switch it works fine with the magnet. Does anyone know why I can't get continuity on the terminal block with a magnet? Thank you in advance
