Which 3D Printer
ge_rik
1,251
Cheshire
www.riksrailway.blogspot.com
I've had great luck with my Creality 10S. Its the big brother of the ender. You get larger print volume.
This one has a build volume of 300 X 300 X 400, which I think is comparable to the cr-10?
Rik
musket the dog
31 Oct 2009
787
143
Leicester
nlrr.webs.com
Finally, I can begin to share some of my own experiences in the world of domestic 3D printing. In the end I purchased my Ender 5 from a website called TomTop.com. Another Chinese distributor with warehouses in Europe and North America. There was less information available about them then BangGood or AliExpress but again no horror stories or reports of them being out-and-out a scam. At the time they were advertising the Ender 5 for £200 with free shipping. All the necessary protections were in place so I decided to take the risk and ordered on the Monday night. By Friday I had a card from Parcel Force saying I had missed the delivery. Fast forward to next Friday and I had managed to get to the Post Office while it was open to collect my parcel.
First impressions were good, no damage to the box, all was branded as Creality. When I had opened it up everything was very snugly packaged inside of some dense foam.
There was an instruction booklet that laid out everything clearly and in fairly decent English. Within an hour I had built the whole thing and was ready to start connecting up all of the wires. All the plugs come with tags for what axis they control. There are two per axis, one 4-pin, one 8-pin so it would be very difficult to connect any to the wrong places. The rest are colour coded and all on identical 2-pin plugs.
The building consists of screwing in the 4 vertical posts. The upper gantry with the extruder bolts on top of this. Finally the bed and Z gantry bolt between the upper and lower of the chassis. The control panel and the filament reel bolt to any of the 4 uprights. These don't need to be attached to the chassis, making things a little easier if you need to move things around if you build an enclosure. All the tools needed to disassemble every aspect of the printer are included (5 hex keys, 2 spanners and a screwdriver) as well as a scraper, a pair of end snips and a Micro SD card and a USB reader. The SD card has the Creality slicing and control software already loaded. As well as some parts for test printing.
I have placed it on the end of my work bench temporarily; my eventual plan being to upcycle an old cabinet into an enclosure. For this I plan I will need a couple of extra computer fans to control airflow in or out. I might be able to power these straight from the power supply for the Ender. I would also like to add lights and a thermometer for the airspace. If using computer case components I think it should be possible to power these from the power supply for the printer too.
As I ordered from a German warehouse the printer came with an EU 2-pin plug. However the PSU for the printer is a standard computer part so I could swap the cable straight out for a spare I had from an old recycled PC with the 3-pin PC socket on the end.
The bed levelling was simple enough, and the instructions explained how to feed in the filament easily. I'm testing using the PLA supplied with the printer but I have a roll of ABS from Amazon's 3D warehouse to replace it. Currently it is printing an Alpaca test piece for SWMBO.
JimmyB
23 Feb 2018
7,082
942
70
Weston-super-Mare
www.tumble-down-falls.co.uk
All seems well, a bit like a suspense movie, what com Ned the.
musket the dog
31 Oct 2009
787
143
Leicester
nlrr.webs.com
Unfortunately Alpaca patient 1.0 didn't make it. The print made it about 75% of the way through before the part became detached from the print bed and decapitated him. The quality is good, and the legs fold exactly as they are meant to.
Reading up on why PLA is likely to detach, bed temperature seems to be a key issue. Another common tip is to add a 'brim' or 'raft' to the part to increase the surface area of the bed. I've played around with a few printers but Cura is completely new to me. Instead of jumping straight into the settings within I found something large and flat to test the brim printing theory. Cue one 'R' key fob. Fortunately it was a quick 20 minute print because about halfway through the part got stuck to the extruder head.
I tried again this morning and manually overrode the g-code file and upped the bed temp to 60c. 20 minutes later I had a key fob! Roughly 35mm x 55mm.
So currently, Alpaca 2.0 is printing. This time I opened up the 'advanced' print settings within Cura. The bed temp was upped to 70c and extruder fan speed dropped to 75%. I slowed the maximum travel speed of the extruder slightly too.
I think most importantly I was able to add in a brim around the part to increase the surface area on the print bed. I could also enable a 'z-hop'. This means that every time the extruder stops and moves to another point of the model to print again it will drop the bed slightly so there is less chance of the extruder head colliding with the model. New alpaca is currently 31% in, all good so far.
I know that the benefit of printing is that modelling can be happening in the background while you get on with other tasks, but so far I can't stop watching it o_O
3,563
Well, it is probably more entertaining than watching paint dry? :p:wondering::giggle:
FatherMcD
13 Mar 2014
394
36
Idaho
United-States
Has anyone had experience with PETG plastic for printing?
trammayo
4,710
Co. Mayo
Ireland
