Roll-wagen project
jameshilton
22 Nov 2010
5,707
66
Near Llangollen, United Kingdom
ejklr.blogspot.com
Hi guys - I'm pondering another project - and wondered about building a roll-wagen... something 'like' this...
http://www.modelleisenbahn.com/p/86/34595.jpg
Rather than use standard size LGB wheelsets I wondered how big the feldbahn wheels are - to lower the centre of gravity. What are my other options? Is there an American or European modern bogie image wagon in 1:29 that uses smaller diameter wheels than LGB (which by my measurements are about 25.5mm rolling diameter) that I could then use the bogies from as well?
Any help MUCH appreciated :)
I'll probably use a standard LGB wagon like this (http://www.dragon-gscale.co.uk/lgb-40883-obb-high-side-gondola-2692-p.asp) as < Link To http://www.dragon-gscale....la-2692-p.asp) as the load with standard gauge buffers, as I think a full on standard gauge wagon would, despite being prototypical, just look odd! With that in mind I'm not sure what 'gauge' my roll-wagen will be, I'm just starting to do some proof of concept sketches and some rough CAD drawings.
jameshilton
22 Nov 2010
5,707
66
ejklr.blogspot.com
peterbunce
1880's Colorado Narrow gauge on 45mm track
29 Oct 2009
1,754
16
east of manchester
Re:Roll-wagen project - wheel sizes??? HELP NEEDED!!
Hi Jamers, Brandbright do 20mm 45mm gauge wheels: 2 axles for £6.25 + post
Have a look under wheels, then price list from
http://www.brandbright.co.uk/
jameshilton
22 Nov 2010
5,707
66
ejklr.blogspot.com
DoctorM
Interests: Manifold
2 Jan 2011
1,126
6
SE London
Don't Brandbright wheels short the rails through the axle? - I thought they were uninsulated and only used by RCers and live steamers.
JonathanJ
South African Railways, Garratts, PRR.
8
Tyne and Wear
Haven't got any drawings of Austrian ones, but metre gauge Harz roll-wagens have a load floor 510mm above rail, and the wheels are between 550and 600mm rolling diameter - I'd guess 580mm, which is a common measurement for some arcane reason.
IP engineering will sell you 45mm gauge wheels in 20, 24 and 30mm diameter, but my preference n low-cost metal wheels is for accucraft - the wheels on their L&B stock are 25mm (W&L has 30mm) and readily available as spares (part Z4).
J.
hornbeam
1,881
What points are you using? Tenmille do some as well, but 25mm Brandbright now offer 20mm ( or smaller as per the ones used in their hudson tipper kits) ones insulated I think the wheels are nylon. Maybe worth calling them. Reason I ask about points is lgb won't bounce in the frog as they have really deep flanges.
5,009
76
James,
Bachman also do a smaller wheel than standard, I think that they pretty much match the LGB Feldbahn ones. They are for the Tippers etc. Much Cheeper than the LGB ones.
jameshilton
22 Nov 2010
5,707
66
ejklr.blogspot.com
Paul - excellent - I think you have my email address already - if not PM me.
The photos I've found of the OBB and Zillertal ones show outside framed narrow gauge bogies inside the frame, but I will source some wheels and mock some things up. I've found some side drawings to confirm sizes and wheel diameters in Schmalspuring Durch Osterreich. Once I've knocked up my own sketch I'll upload it here for anyone else interested. I've also started sketching construction and detail drawings in my sketchbook - check out the post on my blog (link by clicking the photo in my signature).
PaulRhB
This Way Up
408
Wilts Drifting toward the RhB,plate tectonics rock
jameshilton
22 Nov 2010
5,707
66
ejklr.blogspot.com
I think the Austrian ones use 500mm diameter wheelsets, that scale out about 23mm in 1:22. Smaller wheels will allow a lower centre of gravity. I have confirmed with Brandbright that there wheelsets are NOT insulated, and despite the website, only do down to 24.5mm diameter. Useful confirmation for other track powered modellers.
Rhinochugger
Retired Oik
4,254
North West Norfolk
I have a wheel fetish :D and have spent a lot of time researching available wheelsets for 45mm.
LGB Feldbhan are the only regularly available 20 mm diameter ones that I have found (have never looked at the Champex Lindbhan site).
Bachmann small wheels are 24.5 mm dia.
Brandbright wheels need to be researched with care - their own ones are not insulated.
GRS have a selection, but I don't think any of them are their own make - in other words, you'll find the same stuff elsewhere.
I've used the Feldbhan wheels for loco pony trucks, as they are metal with plastic inserts so can work with plunger pick-ups :clap::clap::clap:
jameshilton
22 Nov 2010
5,707
66
ejklr.blogspot.com
Hmmm I'm thinking the LGB ones are the ones to go for to ensure smooth running on LGB track as I don't want bouncing over the frog with any of these alternatives having a more conventionally sized flange!? Is that the general consensus?
jameshilton
22 Nov 2010
5,707
66
ejklr.blogspot.com
I've been doing some sketches to work out sizing, and have shared it below to help any other modellers in the future as it captures critical dimensions. I'm basing mine on one of the 10 OBB 4 axle ones, 8000mm in length.
I've shown it against a standard LGB van, and with a load of one of the LGB 'standard gauge' models - a bit of a comprimise, but probably a sensible one at this stage. The standard gauge wagon is another project in itself, as I suspect it will be a bit more involved than some of Mel's lovely bashes for the WGLR as I don't think I could use the Thomas coach chassis.
Those that haven't seen these in use check out James Waite's inspiring photos of the Waldviertalbahn around Gmund in the 1970s... http://www.narrow-gauge.co.uk/gallery/133 This really does make my proposal look silly with the LGB standard gauge wagon load - however it's my railway yada yada and it'll be a decent start I think and different enough from most lines to be noticeably Austrian narrow gauge straight away!
PaulRhB
This Way Up
408
The only issue with lgb axles might be doing the inside bearings for the rollwagen, as they are mainly plastic in the centre be very careful to avoid twisting or they'll go back on wonky. What are you going to use for the bearings?
